I'm creating a custom OTL. In the create new parameters ection can you reference its fellow parameters?
For example if I created a menu of 3 strings could I get the currently selected string to be displayed in a seperate label field?
My eventual aim is to be able to build operator paths from these drop down menus.
Is there some really healthy documentation on this somewhere?
Custom Subnet OTLs and their UI
5404 5 1-
- Henster
- 196 posts
- goldfarb
- 3465 posts
- Henster
- 196 posts
- JColdrick
- 4140 posts
Check out the strcat(str1,str2) expression.
JUST to be sure
, you do know that there's a type of param called “Operator Path” that will allow the enduser to enter a path to an existing op? Obviously I'm unsure why you may need to break things up to assemble this sort of thing - but just in case…
J.C.
JUST to be sure
J.C.
John Coldrick
- Henster
- 196 posts
- Henster
- 196 posts
Ah. got it. I was being daft.
I was trying to do it to filter the number of selectable ops with more control than the built in filter thing. I'm creating an interface to be used by someone else so the easier the better really. I think I'll just stick to the operator path one. Easier for me
Henster
