how to create a loft shape based on two rectangles
5376 8 3- oat
- 479 posts
- Jenny
- 121 posts
- oat
- 479 posts
- oat
- 479 posts
- oat
- 479 posts
- Jenny
- 121 posts
- zarti
- 330 posts
hi ,
this is my suggestion ..
just put both prim's IDs separately on “subnet1” parameters .
i simply used the Transform SOP to avoid the probs with the points' disorder .
works fine on parallel prims . if you need to rotate them separately , dive inside the “subnet1” and fill the rotation inputs with some maths ..
.cheers
.cheers
except the things that cannot be seen , nothing is like it seems .
- digitallysane
- 1192 posts
Haven't checked Zarti's file, maybe it's the same thing.
If the 2 polygons (box faces) actually exist, then a Skin SOP should do the surface. Might need to fiddle with point order/sort/shift vertices.
If the 2 faces don't actually exist (they're holes) then Divide SOP>Remove shared edges, followed by the same Skin SOP. The resulting geo then merged with the original boxes and fused.
Dragos
Dragos
- oat
- 479 posts
