sweep sop and custom point attrs
   3734   3   3
Is it possible to pass a custom point attribute into the “Scale” property of the sweep sop? In other words, each point on my backbone curve has a ‘myScale’ attribute and I want each cross section geometry to be uniquely scaled according to myScale. Sample hip is attached.
Thanks for any help.
-Greg
sweep_sop.hip (66.2 KB)
that is because $MYSCALE is not available as a local variable since circle1 is the mesh you are feeding as the main input of the sweep SOP. $MYSCALE is only available as a local variable for operators that use create_scale_attr as their main input (like the ray SOP I added to your example)
You can however use point() to actually get the value, like this:
point(“../create_scale_attr”, $PT, “myScale”, 0)
sweep_sop_133_fix.hipnc (72.2 KB)
-G
You can by using the “point” expression.
cheers
sweep_sop_133.hipnc (67.5 KB)
Toronto - ON
Thank you both for your help.
