Hscript syntax
   10490   13   1
I'm trying to create a string that will be used as a parm. The quote syntax is slowly killing me.
for i = 1 to 10
set colour_R = ‘pic(“/img/img2/Line_Color”,0.5,’ + $i + ‘,R)’
opparm $node3 color ( $colour_R 0.5 0.3 1 )
end
This is the jist of it. The priority and limitations of ' and ` and " are confusing.
Does the back slash work for more than protecting the hash character.
Cheers
( acknowledged, having a UV value going from 1 to 10 is daft )
Henster
for i = 1 to 10
end
What are you trying to do? The syntax can be completely different based on the result you want.
Do you want the pic() expression to be evaluated? Do you want the pic expression to be in the channel?
Details details details.
Sorry, not concentrating.
I'd like the expression in the channel, not evaluated.
so the channels read:
pic(“/img/img2/Line_Color”,0.5,1,R) 0.5 0.3 1
pic(“/img/img2/Line_Color”,0.5,2,R) 0.5 0.3 1
What happened to the RFE on a `remove problem` button? I'm sure it was suggested…
Cheers
Henster
Henster
Right now this is implemented in the web browser as “New Topic” in which you may write the problem in simple english and a panel of enthusiasts are all ready to help.
Great! Could the same enthusiasts help with an `upgrade system` button?
Henster
Type your expression into a parameter and then run opscript on that node. That should give you the correct code.
Getting the string into the channel is not a problem. Its the concatenation of the mixture of variables and strings that is confusing me. Even trial and error just didn't seem to be getting me anywhere.
Henster
Then you want to evaluate the expression in your loop then. You can't put expressions into parameters via opparm.
Assuming that, then you want:
set colour_R = `pic(“/img/img2/Line_Color”,0.5,$i,D_CR)`
I'll try re-phrasing this. Must be going wrong somewhere.
I would like $i to evalute in the loop, but the rest to remain.
I'm creating multiple nodes and inserting this expression. So in the channel box for red reads:
Node 1:
Node 2:
Node 3:
pic(“/img/img2/Line_Color”,0.5,3,R)
Hope this makes it a little clearer
H
Henster
Right, read the first reply I wrote in this thread. See also the recent question on opparm in the mailing list.
chadd -t 0 0 strip_colour colorr
chkey -t 0 -v 1 -m 0 -a 1 -F ‘pic(“/img/img2/Line_Color”,0.5,1,R)’ strip_colour/colorr
is the opscript ouput from the first node when I make the nodes manually.
I don't see how this opscript output helps me with sticking the string together in hscript.
The value of $i in reality is evaluated elsewhere in the script and is usually different upon each execution, as is the number of nodes. So just writing out each expression by hand would not work.
I understand now that chadd and chkey are required as opposed to opparm.
Henster
Hey Henster,
Have you tried just catting the two ends with ‘$i’ in the middle?… something like:
chkey -t 0 -v 1 -m 0 -a 1 -F `strcat(strcat('pic(\“/img/img2/Line_Color\”,0.5,',$i),“,R)”)` strip_colour/colorr
Butt-ugly, I agree!… but; who knows, it might just work
Mario Marengo
Senior Developer at Folks VFX [folksvfx.com] in Toronto, Canada.
Thanks Mario. Its working now.
It was those back slashes.
I easily get confused with the butt-ugliness of those cat functions. The big + signs work better for me….
chkey -t 0 -v 1 -m 0 -a 1 -F `“pic(\”/img/img2/Line_Color\“,0.5,” + $i + “,R)”` strip_color/colorr
Thanks again,
H
Henster
Henster
Hehe… yup; forgot all about them fancy + signs (still stuck in the stone age over here) … and they were all over the thread too, lol! (note to self: next time read the whole thread before posting)
But look at it on the bright side: using the functions reminds you that what you're building is an expression. The + operators also become functions (internally, something like string.operator+()), but it's harder to see this. Which means that both forms need the single back-quotes surrounding the whole thing…. which you were also missing in your attempts…. not just the back slashes.
There; I justified my archaic, butt-ugly ways. Ha!
Mario Marengo
