Houdini crashes on start up
5237
6
2
scythargon
June 10, 2012 3:17 p.m.
Hi, everybody.
So, what i've got:
7522: Fatal error: Segmentation Fault Saving application data to /tmp/argon.7522.hip Crash log saved to /tmp/crashlog_argon.txt and /tmp/crashlog_argon.txt is:
Crash report from argon; Houdini Master Version 12.0.634 Traceback from Mon Jun 11 02:08:56 2012 Caught signal 11 createCrashLog(UTsignalHandlerArg, char const*) <libHoudiniUI.so> AP_Interface::coredumpHandler(UTsignalHandlerArg) <libHoudiniUI.so> UT_Signal::processSignal(int, siginfo*, void*) <libHoudiniUT.so> system parameters: 32-bit ubuntu 12.04, unity, python 2.7.3, gcc 4.6.3.
The installation went ok (installed to default dir as root)
Help me please.
June 20, 2012 11:51 a.m.
maybe your temp drive (c:\\ or …) is full. check it
scythargon
June 20, 2012 11:55 a.m.
hmmm… i am on ubuntu… and there are a lot of space on hard drive…
silvina
June 20, 2012 1:39 p.m.
what graphics card/driver are you running?
scythargon
June 20, 2012 1:55 p.m.
“$ lspci -v | grep vga -i” says: "VGA compatible controller: Intel Corporation N10 Family Integrated Graphics Controller (rev 02) (prog-if 00 ) “ yep, im using netbook with Intel Atom N570 on the board. wikipedia says that it contains ”GMA 3150“ graphics cat /var/log/Xorg.0.log: ” X.Org Video Driver: 11.0 X.Org XInput driver : 16.0 " something else?
edward
June 21, 2012 12:05 a.m.
Does running the License Administrator bring up a dialog without crashing? If that crashes, then it's definitely due to graphics drivers. I'd also try turning off compiz/desktop effects if that is enabled.
scythargon
June 21, 2012 5:40 a.m.
License Administrator does not crash - im already set the license with it without any problem.
