Copy SOP swap input.. bug?
   3067   4   1
Im not sure if this is a bug but sometimes when I re-open my scene my copy SOP inputs are getting swapped, im modeling a tank currently and I make heavy abuse of the copy sop currently.. really annoying that I have to swap these inputs back sometimes..
Is this a shortcut I accidently press? Or is this a bug..?
The keyboard “r” will swap your inputs, maybe you accidentally push this somewhere in the process?
Yes this can be possible.. the strange thing is that all my node were swapped.. merge, copy, creep my theory is when I tried to type: “translate” to get the translate node and missed the TAB key before typing it..
Makes sense.. A for select all and R for swap..
Sometimes you accidentally miss the tab key and start typing which often messes up your network view. In such a case, just retype whatever you were typing and chances are you will undo all changes you just made to the network view because most keystrokes are toggles.
Ah yes thanks for the tip!
Unfortunatly I've been fixed the swapped nodes so I'll have to fix the other leftovers.. too many nodes..
