Using point velocities to move fluids
3529 2 1- NFX
- 183 posts
So I am playing around with using houdini to force smoke to take on shapes and flow where directed. While I think I have figured out how to control shape to a large extent by controlling the temperature and diffusion I keep getting wierd results when I try to use custom velocity fields to control the movement. In this case I want the velocity field to be blasting the smoke at a pretty high velocity, however I can never seem to get the smoke moving any faster then normal. Also if I set the velocity fields to copy in the simulation the smoke does not seem to move. Any ideas what I'm doing wrong?
- tamte
- 8449 posts
- NFX
- 183 posts
