I've got a weird “problem” happening when using Lambertian lighting in the lighting model VOP. When I eliminate my ambient light there's no change to the image even though there's a call to ambient() in the VEX code.
H6.1.208 on WIN-XP
Any ideas why ambient() may not be returning a value?
TIA!
–Mark
ambient() call in lighting model VOP
3657 4 2- xiondebra
- 543 posts
- 911Operator
- 19 posts
- xiondebra
- 543 posts
The code looks correct to me, but when adjusting or deleting the ambient light in my scene, there's no change to the image. I also checked my light masks, they're set correctly. The code is being gen'd by the VEX builder, here's the section in question:
<SNIP>
if (0)
color12 = hsvtorgb(colormix(rgbtohsv(color10),
rgbtohsv(color11),
shaded_relief_amount, 1));
else
color12 = colormix(color10, color11, shaded_relief_amount, 1);
// Code produced by: lighting1
vector ii = 0 ? { 0.0, 0.0, 0.0 } : normalize(I);
vector nf = 0 ? { 0.0, 0.0, 0.0 } : normalize(N);
if (1) nf = frontface(nf, ii);
if (lmodel == “constant”)
color13 = color12;
else if (lmodel == “lambert”)
color13 = { 0, 0, 0 } * ambient()
+ color12 * diffuse(nf);
else if (lmodel == “headlight”)
color13 = color12*clamp(dot(nf, -ii), 0, 1);
else if (lmodel == “oren”)
+ color12 * diffuse(nf, -ii, 0.05);
else if (lmodel == “phong”)
+ { 0, 0, 0 } * phong(nf, -ii, 1.0/0.05);
else if (lmodel == “blinn”)
+ { 0, 0, 0 } * blinn(nf, -ii, 0.05);
else if (lmodel == “anisotropic”)
+ { 0, 0, 0 } * anisotropic(nf, -ii, 0.05, 0.05);
else
+ { 0, 0, 0 } * specular(nf, -ii, 0.05);
// Code produced by: output1
Cf = color13;
<SNIP>
if (0)
rgbtohsv(color11),
else
color13 = color12;
else
Cf = color13;
You are no age between space
- Mario Marengo
- 941 posts
Hi Mark,
The ambient() function is obviously being called. The problem is that you have “ambient tint” (or whatever it's called) in the lighting-model VOP set to {0,0,0}.
At least that's what this bit from your code-dump says:
I'm talking about the {0,0,0} in the color13 = { 0, 0, 0 } * ambient() line
… and, of course, I'm also assuming that “lmodel” resolves to the string “lambert”.
Cheers!
Cheers!
- xiondebra
- 543 posts
