Vertices from COP Image
2340 4 1- dulo
- 383 posts
- dulo
- 383 posts
With trace fuse and sort I succeeded in creating the Pointcloud I wanted to achive, but if I export the randomly sorted Pointcloud into an obj for example the point order is absolutely not random. In the obj the points are iterated from top left to bottom right, but I would need random points in the object.
So my next question would be how to create an .obj from my pointcloud with random point order…
An how can I get rid of the polygons ? I just want to have the point. blast alway killed all polys and points.
thx
thx
- zarti
- 330 posts
- dulo
- 383 posts
zartiWorks perfectly now. If I place the Geometry ROP after the Sort Node and this after Point Add SOP the Vertices are randomly mixed in the .obj file. If there were polygons left, the vertex index in houdini was random, but in the exported file it was not.
you can remove geometry but keep points using an Add SOP .
.cheers
- robonilla
- 84 posts
