importing geometry from modo
   2875   4   2
whats the best way to bring the geometry from modo, i try it exporting the geometry as Lwo format (lightwave) but when i import it, it give me an error saying that can read the geometry.
have any one try something like that?
Thanks.
I think the Alembic format is a good way for you
Rabiee.Sadjad@Gmail.Com
OBJ works here without problems.
if you do it as obj you have to import each obj?
or it bring them as groups?(i will try it in the night)
(i have a building with lots of meshes.)
In Modo under prefs check export items as groups. And than items it modo will be groups in Houdini. If that is uncheked than Polygon parts will be groups in Houdini.
