export CHOP, how do you use it?
   3803   4   1
Hi all-
I am using the export CHOP for the first time and I am following the help window directions. However, it does not seem to be working properly.
I imported a .chan file from maya and all of the channels showed up in the graph view. This was done with the file CHOP. Then I piped the export CHOP out of the file CHOP and in the export CHOP told it to use the the correct curve, told it to go to obj/cam1, then told it to go to the tx channel.
This is supposed to override the /obj/cam1/tx channel right? It is not doing this.
Which step have I missed?
-Jon
do you have the orange export flag enabled on the export chop?
that should do it…
-dave
Dave Quirus
Thanks Dave!
In the end I actually just ditched the export CHOP and used only a single file CHOP. In the cameras T(XYZ) and R(XYZ) I copied and pasted:
chop(“/ch/ch1/file/channel1”)
and changed the channel number accordingly. Same effect.
-jon
The advantage of using the export chop is that you can key it's effect to turn it on/off by using the second input.
Simon-
I saw that feature, and I have no idea what to use for the second input. Any recommendations on an appropriate CHOP?
-Jon
