Hi All-
Prolly an easy solution, but how does one render out a shadow pass?
-jon
rendering a shadow pass?
4710 4 2- vrljc
- 63 posts
- EigenAlex
- 639 posts
- vrljc
- 63 posts
- deecue
- 412 posts
jon,
go into SHOPs and lay down a “Vex Shadow Matte Shader” as Alex said. Then go to OBJ. Select the objects that the shadow is casted on (your ground plane) and on the shading tab, point your Shop Surface to the Shadow Matte Shader from SHOPs.
You'll be suprised at how easy it is once you've done it.
hth,
dave
hth,
dave
Dave Quirus
- Simon
- 2199 posts
