Simulation Pre-Run
   2951   2   2
Hi there
I would like to pre-run a simulation to reach a certain state before frame 1. My guess would be to set the “Start Frame” of the DOPNetwork to a negative value, i.e. -50 or so, but I m not sure if that is the correct way…
Any suggestions?
Rgs,
michael
Dr. Michael Boeni
Team-IMX
That is correct, but you also need to set your frame range to start on that same frame and all your objects need to be tweaked to enable “creation frame specifies simulation frame”
Cheers
Toronto - ON
Ah okay - thanks. I'll give it a spin…
Dr. Michael Boeni
Team-IMX
