orient l-systems copies to point normals?
2510
2
1
cgbeige
June 20, 2013 12:43 p.m.
I am trying to copy an l-system tree to the flipped normals of a poly sphere and it's not orienting them correctly. They should face the interior of the sphere according to the normals but they aren't.
tamte
June 20, 2013 2:33 p.m.
well, they should, but keep in mind that copy aligns Z axis with normal simple example (but if you animate the sphere you will need upvector as well)
copy.hip (60.6 KB)
Tomas Slancik FX Supervisor Method Studios, NY
old_school
June 23, 2013 7:53 a.m.
If there are point normals present, these will be used. Reversing the direction of the primitive normals will have no effect on orientation. Try reversing the point normals in a Point SOP: -$NX -$NY -$NZ
