i'm trying to add new points and primitives to an existing geometry in a DOP with the HDK.
this is what I'm doing:
//from the SIM_Object i find the object i want
SIM_Object *sim_obj = objects.findObjectById(obj_id);
const SIM_Geometry* sim_geo = sim_obj->getGeometry();
GU_DetailHandleAutoReadLock gdl(sim_geo->getGeometry());
const GU_Detail *gdp = gdl.getGdp();
gdp->appendPointOffset();
i can't add anything to the gdp. i get errors like this whenever i try (in this example, appendPointOffset):
error: passing ‘const GU_Detail’ as ‘this’ argument of ‘GA_Offset GEO_Detail::appendPointOffset()’ discards qualifiers
i think it might be because i should be using GU_DetailHandleAutoWriteLock instead of the GU_DetailHandleAutoReadLock, but I can't use the Write version. I get an error like this:
error: no matching function for call to ‘GU_DetailHandleAutoWriteLock::GU_DetailHandleAutoWriteLock(GU_ConstDetailHandle)’
any clues as to how i can do this? thanks.
HDK add points, vertices, primitives to SIM_Geometry
3714 3 1-
- stkeg
- 69 posts
- cwhite
- 794 posts
You'll want to use SIM_GeometryCopy (there's an example in the HDK docs of how to set this up as well).
SIM_GeometryCopy *geo = SIM_DATA_CREATE(obj, SIM_GEOMETRY_DATANAME, SIM_GeometryCopy, SIM_DATA_RETURN_EXISTING | SIM_DATA_ADOPT_EXISTING_ON_DELETE);
GU_DetailHandleAutoWriteLock gdl(geo->lockGeometry());
geo->releaseGeometry();
- stkeg
- 69 posts
- cwhite
- 794 posts
If you use the SIM_DATA_RETURN_EXISTING flag with SIM_DATA_CREATE then that shouldn't happen.
You can look at the Bullet solver for an example of how this works (the source code for it is distributed wtih Houdini). In SIM_SolverBullet.C, SIM_GeometryCopy is used when updating glue constraint networks.
