Does anyone know if there is a way to force a particular legacy format output when writing bgeo files. I have 3rd party dependencies which only work with Houdini 12.1-and-earlier format bgeo files, and so I have to keep around an old version just for outputing those files.
H12.5 certainly has no problem reading old files, is it possible to write them too? Naturally I'm only talking basic geometry types, I'm not expecting to store VDBs in old formats or anything.
Geometry ROP output to a legacy bgeo format
2521 3 2- danwood82
- 48 posts
- sl0throp
- 258 posts
- danwood82
- 48 posts
- robonilla
- 84 posts
sure
write this into your Post Frame Script on your Rop node
import os
path = hou.pwd().parm(“sopoutput”).eval()
newpath = os.path.splitext(path) + “.bgeo”
if os.path.exists(newpath):
os.remove(newpath)
os.rename(path, newpath)
be sure to change the menu at the right side of the Post Script Frame from hscript to Python.
This will convert your “file.bhclassic” or actually “file.whatever” to “file.bgeo”. If the file.bgeo already exists it will overwrite it. If you want to rename it to other than .bgeo change to desired extension inside the code
cheers
import os
os.remove(newpath)
cheers
