I notice that motion blur is not rendered in test renders, but render in ROP Mantra. Is there an option to render motion blur in test images, or is the only way to test mb is to set a ROP Mantra for single frame?
Thank you
Dave Rindner
Motion blur preview in preview render
4086 1 1- Dave_ah
- 436 posts
- stevenong
- 1631 posts
Hi David,
Are you rendering with the “View: Mantra” option or “mantra1” when you click on the Render button in the viewport?
If you are not sure, then Right-Click on the Render button and select “mantra1” which will start a render. My guess is motion blur works for you now.
After you selected “mantra1”, it will be used for all future renders so just left click on the Render button in the viewport. Use Right-Click only when you want to use another ROP.
I hope the above helps!
Cheers!
steven
Cheers!
steven
