Is there a way to change the ui background colour of the channel editor to anything other than black?
Can't find anything under color settings. Maybe one can edit it outside of Houdini.
channel editor background colour
4964 5 1- Werner Ziemerink
- 1265 posts
- anon_user_37409885
- 4189 posts
- Werner Ziemerink
- 1265 posts
- Angel Fucaraccio
- 55 posts
- goldleaf
- 4159 posts
You can override that file without editing the installation, by copying that file to a ‘config’ folder in your user preferences (create it if it doesn’t exist), i.e.
Hope that helps!
%HOME%\houdini17.5\config\
on Windows or ~/houdini17.5/config/
on Unix. Pretty much anything inside the installation’s “houdini” folder you can override for yourself by putting in your preferences.Hope that helps!
Edited by goldleaf - May 24, 2019 05:33:37
I'm o.d.d.
- BabaJ
- 2036 posts
Thought this post was interesting and tried to give it a whirl…and although it's an old post by Werner…same here can't make changes.
Have a copy of UILight.hcs;
%HOME%\houdini17.5\config\UILight.hcs
made changes as Angel:
ChannelEditorBackground: 0.25 0.25 0.25 // Background of the graph
Still black though.
Interesting also, I tried copying UIDark.hcs to same directory as UILight.hcs, but get all kinds of pop up errors streaming anytime an action is taken in the hip session. Have to close it with Task Manager.
Although I can copy UIPro.hcs no problems.
My background is set to Light as default.
Still black though.
