Hi everyone, i have a very small problem…I'm trying to get a vehicle to follow a curve on a very bumpy surface….i have the vehicle to follow the path fine, but i want the path to accurately represent the bumpiness of the ground. Is there a way of like projecting the curve onto the surface? If so, what exactly do i have to do to do it? I'm thinking some sort of resampling to increase the number of points on the curve, but what next…?
Thanks for the help!!
projecting a curve onto a bumpy surface
5113 5 1- PenguinOfDeath
- 15 posts
- Siavash Tehrani
- 710 posts
- PenguinOfDeath
- 15 posts
Thanks for the quick reply…i've done that, but it doesn't seem to work over the areas of the ground where i have pushed the ground DOWN using the sculpt SOP. It seems to work fine over the rest of the surface, but… I've tried playing around with the resampling parameters, cos i thought it was due to there not being enough points, but it doesn't seem to make any effect.
- Moose
- 52 posts
It may be overkill for what you want, but Renato Tarabella has a great example file on his site that may give you a few ideas - http://www.tarabella.it/Houdini/Houdini.html [tarabella.it]
- Simon
- 2199 posts
PenguinOfDeath
Add a facet sop to your line and turn on precompute normals. This will show you the direction in which the rays will be projected. You then need to move your line in the opposite direction until it is completely above or below the surface you are raying onto. If some parts are above and some below the rays will miss some parts.
Alternatively try turning on ray by minimum distance rather than projected.
- PenguinOfDeath
- 15 posts
