a problem using rmands
   2903   2   0
hello. i've been trying to connect renderman to houdini. everything works fine untill i use rmands to convert an slo file into an otl.
when i type in the command:
rmands -l wood.otl wood.slo, i get an error message:
rmands error wood.slo: Unable to run sloinfo on ./wodd.
does anybody know how to overcome this? Thank you very much,
Luka
I guessing that rmands uses sloinfo.
you might want to check that sloinfo is in your $PATH variable.
Awesome, that worked! Thanks a lot!
Luka
