I am delaying upgrading from Mavericks on my main iMac until Houdini specs mention Yosemite.
I have upgraded my MacBook, and did find the trick of running Houdini from the shell to get rendering to work - apart from that Houdini appears to run ok but I would rather not take the risk.
Maybe sidefx won't bother and make 14 work with Yosemite.
Any information?
Any timeline for OSX 10.10 Yosemite?
3140 6 0- mmc
- 30 posts
- tinyparticle
- 175 posts
- mmc
- 30 posts
- tinyparticle
- 175 posts
- mmc
- 30 posts
tinyparticle
I am using Houdini on Mac OSX Yosemite without any problems. What are the other problems that you mention ?
Sorry being misleading. There are no other problems I am aware of. I am wary of moving both my machines to Yosemite when the minimum spec still says Mavericks.
You experience sounds promising though.
Having said all of this I am in the New Year thinking of treating myself to a new windows PC with a decent Nvidia graphics card to get a performance boost before I invest in Indie.
- Enivob
- 2531 posts
One thing to keep in mind is that GPU only really works with the smoke simulator (about 30% increase in speed), it does not boost flip sims or give you any rendering gains like Blender's Cycles.
I am new to Houdini, so correct me if I am wrong, but that is my personal experience as an Indie user with nVidia on Windows.
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- anon_user_37409885
- 4189 posts
Enivob
The GPU/OpenCL speed up depends on the CPU/GPU combination i.e. if you have a great GPU then it can be very fast. You can also run a GPU for OpenGL and another for OpenCL.
Once you become more experienced in Houdini you can quite easily create clean OpenCL based sims that avoid the transfer of data back to ‘normal’ memory and the associated overhead.
Additional you can run OpenCL on the CPU which can be quite nice as memory is usually far greater on there.
Good luck!
