VOPs Viewing
5624 5 2- the_squid
- 132 posts
- Simon
- 2199 posts
- szymon
- 7 posts
- Simon
- 2199 posts
Not 100% sure I follow you, do you mean see the code? Just right click on the shader and go to type properties, then click on the vex code tab.
If you are after getting Houdini to automatically create a VOP network that does the same thing as the code, then you are out of luck. You have to do that manually.
- JColdrick
- 4140 posts
- szymon
- 7 posts
