hi, i want to grow things (not using l-systems) .. very simply, my sop chain is :
curve (the final length and shape of the shoot) > resample > carve (animated to grow shoot)
i want to do 2 things to this…
1 - to grow the shoot in an erratic way ( so the carve moves up the second U with a slightly random noisy motion (i assume generated by a noise equation somehow), currently the equation in the second u is just `$F/200` creating a smooth growth over 200 frames
2 - to wiggle the very tip of the shoot (the point where the carve u is currently at) like its searching for light (so to somehow attach an animated deformation to the last 3 or 4 points that the carve has passed.. (i imagine this may be somewhat more complex than the first problem)
cheers all,
Mark
time lapse style shoots with waving tips, and uneven speed
2875 2 1- MWainwright
- 119 posts
- Simon
- 2199 posts
Try this:
$F/200+noise($F/100,$F/100,$F/100)*0.5
The 100 divisor controls how rapidly the noise function varies and the *0.5 is how much it varies the initial value.
For the second part of your problem try this:
Sort your line after the carve so that point zero is always at the top using a sort sop.
Follow this up with a soft transform sop
Then put
point(“../sort1”,0,“P”,0) point(“../sort1”,0,“P”,1) point(“../sort1”,0,“P”,2)
in the pivot point px py pz channels.
And put
noise($F/100,$F/100,$F/100)*30
in the rz channel
Set the softfall off to something sensible, and maybe animate it over time so that it grows from 0 to the radius you want.
That should get you started….
Then put
And put
in the rz channel
- MWainwright
- 119 posts
