Whenever I click the Record button in the Performance Monitor it always crashes Houdini Indie. Even if I start a new scene.
Problem signature:
Problem Event Name: APPCRASH
Application Name: hindie.exe
Application Version: 13.0.0.621
Application Timestamp: 5488458d
Fault Module Name: libUT.dll
Fault Module Version: 13.0.0.621
Fault Module Timestamp: 54882fc9
Exception Code: c0000005
Exception Offset: 00000000002d1245
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1045
Additional Information 1: 1357
Additional Information 2: 1357c8e26312b49a769b9481edf5e250
Additional Information 3: 644b
Additional Information 4: 644b513a8d2f3e1ba7b5dd72cddc79d7
Has anyone experienced this?
Recording with Performance Monitor crashes H.Indie
2324 2 1- ajz3d
- 466 posts
- martikainen
- 1 posts
- neil_math_comp
- 1743 posts
Please log bug reports for crashes at: https://www.sidefx.com/bugs/submit/ [www.sidefx.com] Please send a HIP file and a clear set of steps for reproducing the crash, (e.g. like below), as well as all of the text you get from Help > About Houdini > Show Details > right-click > Copy Text.
An example set of steps that does not reproduce the crash for me is:
0) Open Houdini.
1) Ctrl+click on the Box shelf tool.
2) Dive into the Geometry object node.
3) Set the x component of the Center parameter to
4) Click on the Performance Monitor tab.
5) Click Record.
6) Press play.
0) Open Houdini.
$T
and press enter.4) Click on the Performance Monitor tab.
5) Click Record.
6) Press play.
