brucelay
April 9, 2005 22:18:12
How can I disable a light? (without adjusting its “dim”)
How can tell Houdini not to render this particular sop or object?
Simon
April 10, 2005 06:32:36
There's an active lights field on the parameters for your output (ie mantra render) by default it is set to * (everything) but you can change this to be whatever lights you want to use from your scene.
For future reference you can do this on a per object basis too, look at the light mask field on the shading tab for each object.
old_school
April 12, 2005 07:11:21
For a quick solution, do as Simon said. The exact syntax to exclude an object from a * (select all wildcard) is:
* ^fill_light
where the * means grab all lights in the scene and the ^ (carot symbol) followed by the name of a light object means “remove me from the list”.
The more robust way is to start using bundles to create categories of lights and manage the lists there.
