Cache import - export Asset
   12589   21   4
Here's another simple asset that reads ANY cache Houdini reads, and writes ANY cache Houdini writes.
I have attached both the .hda assets, and the basic .hip files.
The way to use them to read file sequences is to use “$F3” as the enumerator.
This means:
$ = variable
F = Frame Number
3 = number of digits
So a cache named “Thanassis_001.bgeo” should be: “Thanassis_$F3.bgeo” and will read each file has the Frame number.
The same applies for the Writer. Use the same syntax, BUT DON'T FORGET THE EXTENSION.
Any extension you want it to be, you have to write it.
Just input any object or particle geometry or group into the input and play the timeline.
This is just a learning tool, don't forget.
Post your comments and experiments here.
import_exportAsset.zip (25.5 KB)
Sweet!
-b
http://www.racecar.no [www.racecar.no]
Thank you
also if we have bgeo, it will read also with partioArnold procedural and navie cacher(or write by it) - for complex pipeline :wink:
i'm sorry for my English
One more thing I need to explain..
Unless your Houdini Particles have an “id” attribute, they won't load in C4D.
You can append an “id” using an “Attribute Create”, set it to “integer” and make the expression “$PT”.
That way C4D has a global particle id (essential to C4D) and will load properly.
Don't forget to increase the Max TP count in the TP preferences.
Flip Tanks have an “id” on by default, but whitewater doesn't. Neither do simple point objects, so make sure you have the “id”.
Thank you! The particle ID was my issue. I didn't use the ID Attribute check box on the FLIP solver. My particles are showing up now.
i cant import bgeo sequence… only selected bgeo is opening in my c4d but not as bgeo sequence..
Are you following the instructions in the first post?
You need to change the name to include the frame variable “$F3”.
Do I have to have the Houdini Engine installed to use this in C4D?
Using Houdini Indie
Ubuntu 18.04 48GB Ryzen 16 core.
nVidia 1070GTX 8BG RAM
These are very nice details indeed.
Works quite well (the id trick helped) - however, I can't seem to access particle scale from c4d anyhow.
I can use one of the Cd channels to transfer scale for sure, but, I would like to do this in a proper way, using the pscale parameter (if this is the proper way). C4d can't seem to access this parameter.
Guidance needed!
noseman
noseman
Following your instructions to write file with _$F3 as the end of sequence name, but it only load the frame selected.
hi hi hi
You say “to write” and then “only load”.
Do you want to write a sequence from Cinema 4D, OR Read a sequence into C4D?
noseman
Thanks for your replying, Noseman.
I made a simple test animation in Houdini and cache it out with a file node with a name “test_$F3.bgeo”.
in c4d load your “Houdini_cache_reader_01A” , but when i load the files cached, it only load 1 frame that is selected
Edited by yandao90514 - Nov. 11, 2016 11:42:10
hi hi hi
you need to make the name: “Test_$F3.bgeo”
In the picture it's “Test_001.bgeo”
Replace the frame number from “001” to “$F3”
noseman
Thank you, now it works.
it's little bit confusing, though.
Edited by yandao90514 - Nov. 11, 2016 11:58:32
hi hi hi
not really, it's how you open it in Houdini as well, only it's automatic there.
I'm glad it works now :-)
Cheers
noseman
Cheers
Yet another question, is it possible to load those lines into c4d ? on my test it only loads the polygons.
Edited by yandao90514 - Nov. 11, 2016 12:09:23
hi hi hi
the C4D Houdini Engine plugin doesn't support Splines, I'm afraid.
Cheers
noseman
Cheers
okay, thank you again.
hi hi hi
Hello, sorry to dig up that old thread again, but when I try to load in the .bgeo it just turns red and the doesnt create the geometry. However if I load it in houdini and open the .bgeo file there through your hda it works fine…
Please remember that many Houdini features that can be saved in a bgeo file are not compatible with C4D.
For example:
Splines
Volumes
Particles without explicit ID attribute
e.t.c.
