I am a CG student currently learning basic rendering.
I just still cannot get the “rman volume spotlight”shop working. The light colour of this light shader works fine but I just still cannot see the fog! (even I put “0” in decay, fog density 2)
How can I apply the fog on this light shader-volume spot? Pls help! Any help will be highly appreciated!
volume spot question
2188 2 0- brucelay
- 313 posts
- Mario Marengo
- 941 posts
brucelay
See Application Note #20 in the PRMan documentation.
<edit>
Also see the thread “next door” to this one (here [sidefx.com])
</edit>
- brucelay
- 313 posts
I tried to render a scene with a standard spotlight under the smoke environment with the aid of smoke shader I found fromhotoRealistic RenderMan Application Note #20
smke.sl
but the result looks like a cone with lots of small white dots instead of looking like thin cloud. Which parameter should I tweak I can archieve a thin smoke effects under a spotlight? The step size I used is 0.1 but it already take quite long time to render!
Pls help! Thank you for your attention!
smke.sl
