where, SOP param's, LOC was Pointed out to me
   2138   1   1
Is there a list with all parameters than you can find in a SOP ?
the $CEX or $GCX or new parameters just seem to pop up all over the place when you read these postings explaining things (thnx).
But if you want to find out for yourself which parameters can be evaluated from a certain SOP, Where do you have to look in the online Help for this info?
Ah, Thanks. The forest was starting to crowd the trees.
I have looked up so much info in forums that i forgot to look for it in the obvious place. oops
Edited by - April 28, 2005 09:29:30
These are known as “Local Variables”. They only work within specific operators and should be documented in the help of their respective operators under “Locals”.
