Hi all.
trying to figure out if you can use a lattice to deform an object that is animated in the object level, rather than passing it through the lattice at sop level.
ie. to make the object pass through the a lattice and deform when only animating at object level (the lattice will be at sop level i assume)
so i might have an object in one operator and a lattice in its own op.
does that make sense?
using lattices to deform objects animating at object level.
2206 1 1- MWainwright
- 119 posts
- Simon
- 2199 posts
You'll have to do it with two objects the first has the object level animation and the second object_merges it in and does the lattice, then either merge the result back or just display the second one.
When you object_merge make sure to use “.” in the transform field.
