as suggested in my earlier post (bump map problems) i may be getting shadw artifacts.. the suggested solution was to up the shadow bias in the shadow shader..
but i dont know how to apply a shadow shader.. the shadows in my scene are just from setting shadow casing in the lights.. not applying any shaders..
i hade a shader sop on my model, and i thried adding a vex shadow shader in the shadow shader parameter, but i cant navigate to the actual shader, all i can see is /shops
how do i do it right?
shadow shaders
2304 2 0- MWainwright
- 119 posts
- deecue
- 412 posts
you would add a shadow shader to a light, not a model (unless you are doing light instancing)…
so go to your light at obj and go to the shading tab.. in there there is a SHOP shadow parameter… point it to your shadow shader and you should be set..
(wow.. that was a lot of words starting with sh.. :? )
Dave Quirus
- MWainwright
- 119 posts
