[img88.imageshack.us]
Greetings,
I've got Linux Mandrake 10.1, last NVidia drivers, Houdini 7.0.469., tested in KDE and WinIce
I keep getting this graphical issue with my single file after I press Render:Mantra1, render the image and then choose Desktops->SHops (or just change from Geometry/Objects to Shaders). If I open another file, or hide the selected geometry and change to Shaders - everything is fine… So the reasons could be - some unexpected reaction of Houdini to the texture I've got on my geometry, some drivers issue… or whatever.
On the other hand If I render with View: Mantra and then change to Shaders - everything is fine.. hmmm… I don't get it.
- I made some tests and the bug seems to show itself only of I set the resolution to 640x480. If I set it to 600x450 for example - all is fine.
This is not critical and there are walk-arounds… though it's somewhat nasty.
