Hello
I was not able to make uv Pelt work
Select edges to for the boundary of the belt and press enter to complete
I can't select edge as i usually do , i can only select one edge and disappear after trying to select another one
If i made the selection before clicking on UVPELT , this selection is useless
once i click on UVpelt i can't select any thing
This is wired and annoying. i'm not sure why it does not work
UV Pelt Problem
4904 10 2- Anas Kassis
- 11 posts
- StefanN
- 13 posts
Perhaps this might help:
https://www.sidefx.com/index.php?option=com_content&task=view&id=996&Itemid=255 [sidefx.com]
- Anas Kassis
- 11 posts
- lerninghoudini
- 7 posts
- CGS
- 59 posts
- Ralph Pinel
- 112 posts
- MikaHoo
- 2 posts
Anas Kassis
Hello
Same happens here. Is there fix coming soon?
- tamte
- 8544 posts
seems like pelt selection in H15 is not working properly,but it will only get fixed if you submit a BUG, otherwise it may take longer
in meantime you can do:
1. place UV Pelt SOP and connect to your geo
2. next to Group parameter click the arrow button
3. select seam edges in the viewport and press enter
4. tweak the parameters on UV Pelt SOP
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- MikaHoo
- 2 posts
- garin2
- 37 posts
- ThomasHelzle
- 26 posts
This is still broken as described by the op above in 15.5.673.
I banged my head against it for two hours now before I finally accepted that it's not me doing something wrong but the tool being broken.
The helpfile is completely non-helpful as well. A single picture could probably clarify what the “frame” does much better.
Thanks tamte for the workaround.
Tom
Tom
