Hi
I have a poly line and I want to copy it several times so it would look something like this:
http://prntscr.com/chket7 [prntscr.com]
I tried to set this up (should be simple) but it doesn't work…
Copy stamping error
1906 2 0- SteN
- 55 posts
- Georgie
- 10 posts
Put this in the offset variable on your copy sop : $CY%2==0
Drop a transform sop after your line (and before the copy sop)
Put this in the Translate X : stamp(“../copy1/”, “offset”, 0)
$CY is the copy number. Goes from 0 to however many copies you have. $CY%2 returns 0 for copy0, 1 for copy1, 0 for copy2, 1 for copy3 and so on.
If you want more control, you can put this in the translate X parameter :
if(stamp(“../copy1/”, “offset”, 0), 3, 2 )
- SteN
- 55 posts
