Normal problem when rendering
1779 2 2- Shiva99
- 15 posts
- neil_math_comp
- 1743 posts
Can you post a HIP file? That'd help with figuring out what's gone wrong. If you're using a Merge SOP and one input has N, but another doesn't have N, N will be zero for the geometry that didn't have N before. In that case, there should be a warning on the Merge SOP about mismatched attributes.
- Konstantin Magnus
- 670 posts
