the ability to select wires in the network is fantastic…
I'd like to also be able to select an incoming wire and /copy/ it so that I can feed it into another node without removing it from the node that it is curently feeding into…
eg:
|sphere|
|twist| |blast|
RMB on the wire would provide a way to allow the sphere to feed into the blast without disconnecting it from the twist…
I realize that this eg is far too simple to see the usefulness of this ability…but if you have a big network it would really help…
