Fur disappeared from viewport and render
9537 37 2- ALMINA
- 154 posts
Hello So I decided to use a fur simulation for my characters hair. But one time I had to force quit Houdini then I reopened the file and the hair is not visible in viewport or render!
Does anyone know what might have possibly gone wrong? Because the settings of the hair is just there as before.
I tried creating a new fur simulation and that doesn't show as well!
but it is still loading the fur properly as if it is still there! It might be a visibility problem…
If I made a new project the fur worked.
Someone please help! Thank you!
Edited by ALMINA - Jan. 21, 2017 22:10:11
- matthias_k
- 483 posts
- ALMINA
- 154 posts
Sorry, here is the simplified file with the same fur simulation in it.
Please change the skin to the Head in the file.
https://www.dropbox.com/s/z44cpnwo8zz8dke/Fur_Test.zip?dl=0 [dropbox.com]
- ALMINA
- 154 posts
- matthias_k
- 483 posts
- matthias_k
- 483 posts
- ALMINA
- 154 posts
- matthias_k
- 483 posts
- ALMINA
- 154 posts
- matthias_k
- 483 posts
- matthias_k
- 483 posts
- ALMINA
- 154 posts
- matthias_k
- 483 posts
But I think I had longer hair before…
Ok, then you should ask your hair stylist what he has done
The “Group” is the face set where the fur is assigned
if you have changed the geometry, then you have to reassign
the right faces.
Maybe you should set the cloth to non visible,
and then have a look if you can find “your hair”
somewhere else on the geo.
- ALMINA
- 154 posts
- ALMINA
- 154 posts
Hey, I think the group is right because the paint_fur density is painted at the right place. I looked around his body but couldn't find the hair as well….
It is loading the hair as well but the problem is just that it is not visible!!!
The target skin is only the head anyways because the head and the body is separated for blend shapes.
Edited by ALMINA - Jan. 22, 2017 20:47:02
- ALMINA
- 154 posts
- matthias_k
- 483 posts
- ALMINA
- 154 posts
- ALMINA
- 154 posts
- ALMINA
- 154 posts
Okay, here is the file with the original skin attached to it.
Can you see what is wrong here?
The blend shapes, the material and the other parts of the body is omitted.
https://www.dropbox.com/s/09edofa2q8liguo/Fur_Test%202.zip?dl=0 [dropbox.com]
