Noise in painted areas ?
4274 13 1- _Christopher_
- 761 posts
I want to have noise (vop) only effect painted areas but when binding the override color attribute from the paint sop in a attribute vop; there isn't any noise being applied to only the painted areas, when plugged into Cd; instead my entire mesh is multi-colored ? Must I use the override color parameter; and if so, how ? Sorry a little rusty in that respect
【T】【C】【S】
- sepu
- 419 posts
Define it first upstream then use paint node with “override color” with your custom attribute.
So in a wrangle you can do
then add the paint node and check the override, add the “painted” attribute in the override color and paint whatever you want to override.
Then in a second wrangle connect the paint in the first input and the noise in the second input and just add a lerp function to control how much of the noise you want to see.
f@painted = 0;
@P = lerp(@P , point(1, "P", @ptnum), ch("blend") * f@painted);
Edited by sepu - Feb. 5, 2017 14:47:43
- _Christopher_
- 761 posts
- sepu
- 419 posts
- circusmonkey
- 2624 posts
- _Christopher_
- 761 posts
- circusmonkey
- 2624 posts
- _Christopher_
- 761 posts
- circusmonkey
- 2624 posts
- _Christopher_
- 761 posts
circusmonkey
See attached , id is. The @ symbol , is just used in the wrangle !
Ah, your assigning Cd to the attribute (@noiseid) why didn't you declare it as a float or vector ?
Hrm, I understand your scene
What if I don't want to use the wrangler and do what you did in the wrangler in VOPS ?
【T】【C】【S】
- circusmonkey
- 2624 posts
Floats are automatically declared so @noiseid will be a float automatically.
You could do it all in vops depending on what the rule is, ie @ptnum > 5 .Which would say all point numbers greater than 5 get noise.
Rob
Rob
Gone fishing
- _Christopher_
- 761 posts
- _Christopher_
- 761 posts
- dennisvolkerts
- 16 posts
