Bullet RBD constrained to Wire Object
   1780   3   2
Im simming Bullet RBD and Wire Object in one DOP context, they collide and affect each other, nice.
How can I constrain them together ? Attach two RBD objects with wire ?
See attached hip and image. There is so many constrains in DOPs, which one should I use ? Is Constrain Network the right approach ?
rbdandwire.hipnc (289.0 KB)
Michal Tas Maciejewski @ Weta Digital
don't know if i'm up to date but i think the feedback you are looking for is currently not possible natively.
maybe this is a workaround for you…
http://ihoudini.blogspot.de/2011/10/wire-to-rbd-feedback-in-dops.html?q=wire [ihoudini.blogspot.de]
it's old… but it worked for me on 15.5.717 despite error message
regards
thanks houndman, I checked this method before, the result is bit laggy and doesnt really look realisitic.
I found this statement in docs, so I assumed Constraint Network is the right way to go, I just dont know how to set it up.
Constraint Network
dynamics node
Constrains pairs of RBD objects together according to a polygon network.
Note
This DOP is currently only supported by the Bullet Solver and the Wire Solver.
Did you found an solution for this with constrained networks?
