Hi, I made a marker to try and visualize the point vectors of my Point VOP. Although the points are moving, the vectors always read 0 0 0. Not sure why this is. Thanks for any help on this!
Thanks for the response, it was the only way that I could figure out how to get some form vector marker.. is there a way to have marker show me the position of these points?
sepu with your node selected press X and you will have a visualizer node which by default outputs P then just change to type “marker” then you will see P
