We all love the Geometry Spreadsheet but I believe we will love it even more if the following RFEs could be implemented.
I guess they are listed in order of importance:
a. Have a “Go to Point/Primitive Number” box
Everytime you want to check a Point's or Primitive's attributes which you've isolated in the viewport, you have to scroll & with hundreds of thousands of points, it is a chore. Not to mention if you close the window accidentally, opening a new window starts from the top again.
I know I can select the point(s) or primitive(s) & have Houdini show “Selected” only but most times you don't want to have to do that.
b. Sort attribute values from Minimum to Maximum & vice versa.
Many times I would like to know what the Min & Max values are so I can use them in a fit() function. Of course I can use the Geometry CHOP but all the required information is there in the spreadsheet already.
c. Allow reordering of the attribute columns.
Sometimes, you want to compare two sets of geometry but they have attributes added at different parts of the network so the attribute columns are laid out differently. It would be really nice if we can re-order the columns to line them up.
Cheers!
steven
