Hi there,
I did this:
In hscript:
set -g FOO=0
…and in a Null Object's tx parameter:
run(“set -g FOO=`$FOO+1`;echo $FOO”)
- Now as you step in the playbar and view the result of the equation, you'll see that the number will increase by 4 when the Null Object is is selected and by one when it's not selected.
So it seems like the parameters are excessively cooked when a node is selected. Is there a reason for what I'm seeing happen here? A classic case of overcooking?
Thanks,
Jason
