mtucker
I couldn't replicate this problem.Mark
Hi Mark,
You're right in that the problem doesn't show up with the ParameterVOP. It seems to only happen with parameter definitions in custom vops.
I'm including a hip file to replicate:
1. Open TestString.hip and go into /vex/surface1. In there there is a custom VOP called testString1 with a single string parameter “String”.
2. Open the “Type Properties…” dialogue for the testString1 VOP and also open up a “View Code From VOP Network…” window. In the code window, notice how both sides of the equality conditional are enclosed in quotes. So far so good.
3. In the “Type Properties…” dialogue, set the parameter “String” to “invisible”, hit “Apply”, and refresh the code window. The left side of the conditional should have lost the enclosing quotes (at least it does over here).
I'm testing this on H8.0.412 (SuSE 10)
Thanks.
