Is it me do you find if fast enough and reliable?
I have less problem with dirt mask for example…
vince*
Vincent Thomas (Avalailable early summer 2017)
Senior Lighting Lookdev / Env DigiMatte Artist / Creative Designer VFX supervisor
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
Curvature in H16
2081 2 0- vinyvince
- 255 posts
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
- Simon van de Lagemaat2
- 116 posts
It's unreliable and can suddenly become very very slow in some situations for no apparent reason. Just so you're aware of its status, I filed a bug with content for it and got this response back.
Unfortunately the Curvature VOP *is* really slow.
For baking curvature we switched away from it and use a different method. Parts of it are specific to baking and use some precomputed data though so it can't easily be used as a general purpose replacement for the curvature VOP.
It uses the same algorithm as the Measure SOP - so you could use that to bake the curvature data onto points.
If you need it on subd or displacements you could use the getlocalcurvature() function. That is what the baking tools use and when used on subd/displacement they don't require any precomputation. You may need to massage the output of the function to get usable values.
Edited by Simon van de Lagemaat2 - March 30, 2017 15:40:10
owner the Embassy VFX
- vinyvince
- 255 posts
It become an intense or impossible to compute process with the smooth option on..
Or did i miss something?
