Hello Im trying to assign an expression to a parameter using hScript. Im using the opparm function to assign values to parameters but when I try to assign a expression with it, it doesnt seem to work work.
opparm /obj/bone1 length 123 # Works OK
opparm /obj/bone1 length ‘“$a”*chop(\“/ch/ch1/chopnode/ch1\”)’ # Doesnt Work
Does anyone know how to assign an expression rather than a value to a parameter?
Assigning Expressions with hScript
6672 10 3- Karl_Hansson
- 2 posts
- Simon
- 2199 posts
I think you'll find you have to create a key and then assign the expression to the channel that's created. Unless this has changed in H8.
If you type in what you want manually then do an opscript on the node you should see what is required to reproduce it.
- Karl_Hansson
- 2 posts
- pbowmar
- 7025 posts
- goldfarb
- 3455 posts
- Simon
- 2199 posts
- stevenong
- 1631 posts
- louis dunlevy
- 641 posts
- grasshopper
- 15 posts
Oh yes. Me too!
This seems like a no-brainer. Surely if Houdini sees that the user is opparming an expression then it could just implicitly add the required chadd and chkey commands for you. This must have been an RFE for years.
Furthermore, it is a major hassle to write scripts that copy parameters from one node to another if they have to account for those parameters containing channels. It would be great to make that process smoother too.
- rafal
- 1448 posts
- ben simons
- 387 posts
arctor
so Houdini should just make the channel…
And put a key at Frame-1?
Ahhh…. Frame-1 … the first refuge for the keyless! :-) tee hee.
—–8<——————————————————————————
Actually, I just noticed a bug with a bad opparm and the channel viewer. It can show channels which don't exist anymore. Houdini 8.0.394. Try this in the textport:
opcf /obj
opadd geo thing
chadd thing tx
set one of your panes to be the channel editor . Scope the tx channel . Change the value at frame 1 to be 0.3 say. Now!
opparm thing tx nuthin
you'll see:
Warning: Invalid channel “nuthin” specified in parameter
and the tx channel in the parameter's pane is clear. It's a plain old 0.3 constant. But! In the channel editor it's still there. Hmmm. Now, let's have some fun. Change the 0.3 in the parameters to, say, 0.5. The Channel Editor says 0.3 still. Cool. Now change the value in the channel editor to -2, and move the key to another frame. Frame 42 for example. Noice.
Which is true?
/obj -> opparm -d thing tx
opparm thing tx ( 0.5 )
Oooh! What if we now make a channel in the parameters pane by ALT+LMB clicking on the 0.5. What will happen!?! Yay! A New Key at Frame-1 and a value of -0.1 (and i'm at frame-13; the unlucky frame number).
An “opparm usage error” probably shouldn't blow away a channel.
Actually, that's probably the real bug..
beers!
b.
''You're always doing this: reducing it to science. Why can't it be real?'' – Jackie Tyler
