When rendering I get this error in to console “mantra: No procedural named ‘enginecurvegen’ exists for object /obj/myHairgen”, and no hair/fur renders. I've tried turning hair groom and deform on and off, and also built a basic setup from scratch, but no luck.
Has anyone else run into this issue under linux? I don't get this on windows..
Haven't submitted a bug yet, just wondering if there is a easy fix I'm missing.
thx
Jason
Hair: Procedural not working under linux?
1823 2 0- JasonSlab
- 1533 posts
- mark
- 2591 posts
The enginecurvegen procedural is loaded from a .so/.dll. Is the HOUDINI_DSO_PATH set up to find $HH/dso/mantra/VRAY_ProcEngine.so? (well the MANTRA_DSO_PATH)?
If you runyou should get a list of all the procedurals available to mantra. Setting HOUDINI_DSO_ERROR to 1 or 2 might also help track down dependency issues.
If you run
mantra -V8 < /dev/null
- JasonSlab
- 1533 posts
