Trying to find a tutorial that will address the following
It's probably not necessary but I am curious as to how to do this.
Create one curve on the plane and a second curve above the plane and then fill the space between the curves with geometry.
That's all
Multiple Curves
2897 5 0- marvalgames
- 20 posts
- sepu
- 419 posts
- marvalgames
- 20 posts
- goldfarb
- 3455 posts
- Sadjad Rabiee
- 1391 posts
Hi
as sepu said ,The best method is using Skin SOP ,But I don't know why you said it didn't work for you !!!
I think you try to connect each curve to each input of Skin SOP ,right ? Because for doing that you have to merge both curves with together (via Merge SOP) then connect output of Merge SOP to first input of the Skin SOP ,That's all
- marvalgames
- 20 posts
Joker386
Hi
Yes ! I should have got back sooner. It worked (SKIN). I just didn't merge like you mentioned.
