I just tried to install the Houdini Apprentice 16 in an effort to get acquainted (after a very long time) to the program. My system runs on Linux Mint 8.1 (Ubuntu 16.04 based), KDE Plasma windows manager.
As I go through the installation process, the terminal stops at the following part:
Commencing installation of selected modules.
This may take a few minutes…
Installing: Houdini in /opt/hfs16.0.600…….
Installing: Houdini menus…
Installing apprentice license…
The Houdini 16.0.600 environment has been initialized.
And as I understand, it is the moment when it wants to start the License Administration (I already selected the local licensing during the installation process), but nothing happens.
Is there any additional dependency required?
When I tried to run the Apprentice or the License Administrator from the icons that are in my applications menu, nothing happened and I received no error message whatsoever.
I also tried the terminal command:
/opt/hfs16.0.600/bin/happrentice %F
No error there either, but nothing would start.
The License Administrator simply got no response:
/opt/hfs16.0.600/bin/hkey %F
Any recommendations?
Thank you in advance!
