How can one change the orientation of the surface of a line being rendered?
it seems it tries to orient towards the camera by default.
orientation of line rendering
2151 4 0- jeffMc
- 125 posts
- sl0throp
- 258 posts
This has to do with the way that mantra handles curve rendering. I believe that the curve is projected to screen space and then rendered with a width based on an attribute or a default value. If you want to start rendering it other than that chances are you will need to write a custom shader that does some sort of displacement. As an example, it is pretty easy to make a shader that displaces the surface to look like a tube, rather than a ribbon.
- jeffMc
- 125 posts
- jsmack
- 7741 posts
- jeffMc
- 125 posts
