houdini 16 Indie picking up Apprentice license for outputting Ocean Evaluate textures?
   2219   2   0
I was using Apprentice on this machine for a while. I just bought an Indie license.
I'm trying to output a frame range of texture maps from an oceanEvaluate node. I'm getting a warning saying “Image resolution is larger than 1920x1080(Apprentice HD License limit for sequences of images)”. I am not able to output my 3000x3000 displacement map sequence.
But when I look at the license server I'm using the Indie license. How can I get around this problem?
Please see attached image.
Edited by johnLIC - May 25, 2017 13:24:50
Houdini Indie is limited to 1920x1080 output. When you try to exceed that it invalidates the license and thinks your are an Apprentice user, thus the message. The highest you can output with the Indie license will be 1080x1080, if you need square output.
Try 1080x1080 and see if that works.
Edited by Enivob - May 25, 2017 16:32:15
Using Houdini Indie 20.0
Ubuntu 64GB Ryzen 16 core.
nVidia 3050RTX 8BG RAM.
Thanks for the info. I didn't realize the Indie license was so restricted.
