efficent way to remove millions of particles
   1656   4   1
Is there an efficient way to remove millions of particles that are inside some geometry?
Trying a group node to select points with a bounding object but it is running single thread, which is very slow on 80 million particles. Thanks!
Hey!
Use a bounding vdb volume, it does not have to be high resolution, it is much faster.
daniel bukovec | senior fx td | weta digital
qLib -- http://qlab.github.io/qLib/ [qlab.github.io]
A billizion times faster! thanks buki!
instead of using the group bounding use this in a wrangle you will get some more boost
convert the shape to vdb like daniel said and connect it to the second input of wrangle
and
float in = volumesample(1,0,@P);
if(in < 0)
removepoint(geoself(),@ptnum);
Head of CG @ MPC
CG Supervisor/ Sr. FX TD /
www.timucinozger.com
Cool stuff tricecold! Interestingly both techniques are approx the same speed here on MacOs.
